Traverse for GObjects VI Other Refnum Input Wire Broken
Updated May 25, 2018
When I try to wire the refnum of a page of my Tab Control to the Other Refnum input terminal of the Traverse for GObject VI, the wire is broken. I've already changed the Traverse Target terminal to "Other", what class type does the Traverse for GObject VI accept?
The Traverse for GObjects VI Other Refnum terminal accepts GObject refnums. You can connect the refnum of a different type by typecasting the input refnum to a GObject refnum.
The To More Specific Class function can also be used to change the class type of your refnum.
