How Can I Get The Process Model Path in a TestStand Sequence?
Updated May 30, 2018
  • TestStand
I'm developing a sequence with TestStand and I need to programmatically get the Process Model path, but I don't find the property which contains this information.
The best way to find a TestStand property is creating a dummy sequence (just a Message Popup) and setting a breakpoint on it: when the you run the sequence (Test UUTs) and you are on the breakpoint, with Ctrl+F you can use the Find/Replace. Writing the right key word on the search form you can find the property you need. For example in this case the property is RunState.Root.RunState.SequenceFile.Path
