Drivers Required for CAN over EtherCAT
Updated May 28, 2018
  • NI-XNET
  • NI-CAN
I want to implement a new application where I use LabVIEW to control CAN communication between a cRIO and an EtherCAT device. What drivers do I need?
These are the drivers you will need:
  1. NI-Industrial Communications for EtherCAT
  2. NI-XNET
The version of the drivers must be compatible to the version of your LabVIEW Development Environment.
See the related links for compatibility information and more on working with pre-existing applications that use NI-CAN.
