Selecting the Right Fan Speed for PXI Chassis
Updated Apr 3, 2019
  • PXIe-1078
  • PXI Chassis
The fan speed for my PXI/PXIe chassis can be set to either automatic or high. Is there an indication of when high should be used?
We recommend selecting the high speed option as it offers maximum cooling performance. While with the auto setting the fan speed is determined by the intake air temperature and hence offers a quieter operation.
If the power usage and volume of the noise (from the fans) is not a concern then we recommend using the high setting.
It is also important to note that the specifications also assume that you have selected the high fan speed option.
