Correlated DIO with NI USB M Series DAQ Device
Updated Dec 21, 2022
  • USB-6216
Can I perform correlated DIO with a USB M Series DAQ device?
The externally powered USB M Series devices use the STC 2 ASIC that provides for correlated digital I/O. Correlated digital I/O refers to the ability to provide a sample clock to digital input or output tasks. This clock can come from a number of possible sources; you may refer to the device routes tab in NI Measurement & Automation Explorer (MAX) for a full list. Externally powered M Series USB DAQ devices are numbered 622x, 625x, and 628x.
Bus-powered USB M Series devices (621x) do not support correlated Digital I/O. These devices do not use the same STC 2 chip as other M Series devices. Much of the functionality of the STC 2 is implemented on these devices through an onboard FPGA, but correlated Digital I/O is not included in this feature list.
For more information about the included features on M Series and bus-powered M Series DAQ devices please refer to the manuals linked below. Note that the bus-powered devices have a separate hardware manual from the other M Series devices.
