StatBlockCalc Function not Writing Channel Properties in DIAdem
Updated Oct 9, 2018
  • DIAdem
The StatBlockCalc Function in DIAdem is writing results in the channel properties if the channel range for evaluation (RowNoStr) is not specified. As soon as I change the channel range for evaluation, the properties are not written to the channel.
This is expected behaviour of the function. Only if the whole channel data is used for statistical evaluation, the property is added to the channel. If only a certain range of the channel is evaluated, no channel property is added.
Properties can manually be added by using the ChnStatisticsChannelCalc function.
