Retaining Last Line Values After Bursting a Pattern with the NI PXIe-6570
Updated Jun 15, 2018
  • PXIe-6570
When bursting a pattern I would like to leave the line states at the last state (that was at the end of the pattern). Is there a setting that allows the last state to persist on the line?
To retain the last line states on this device you will need to configure the time sets (in the project's .digitiming file) so that the drive format of the time set used in the pattern's last vector is set to 'NR' (non-return). Setting the drive format to NR for the time set of the last vector in the pattern (the vector with the 'halt' code) will retain the last line values when the pattern finishes bursting.
