Disable Toggle Exclusion Feature in LabWindows™/CVI™
Updated Oct 9, 2018
  • LabWindows/CVI
I keep accidentally disabling code with the toggle exclusion feature by pressing Ctrl+E and it causes unexpected behaviour in my compiled code. The affected lines are colored grey so I don't notice the change.
Is there a way to disable the feature?
There is no setting to disable the feature itself but you can remove the key assignment for the feature. You can change the shortcut key assigments of the LabWindows/CVI environment:
  1.  Go to the menu Options»Change Shortcut Keys...
  1. Find and double click the Toggle Exclusion entry:
  1. Pick No shortcut key in the drop down menu Shortcut Key:
