Support for VI Scripting Functionality
Updated Jun 25, 2018
I am an advanced LabVIEW user and I want to use VI scripting to control my VIs at edit-time. What kind of support can I get for VI Scripting functionality of LabVIEW environment?
VI Scripting is not directly supported by Application Engineering department. As this is a NI Labs product, all technical issues should be posted on the API Community.
This forum is monitored by NI employees. Advanced users and LabVIEW Architects use the forum to share ideas and ask questions, such as VI scripting API questions.
VI Scripting helps you programmatically generate, edit, and inspect LabVIEW code. It contains several new VI Server classes, properties, and methods so you can create, move, and wire objects; edit the connector pane; create new VIs on the fly; and more.
If you would like some VI scripting getting started material, there is a walk-through tutorial available as part of LabVIEW Help.
