Unable to Find My DAQ Device in LabVIEW DAQmx Physical Channel Control
Updated Mar 5, 2024
I have hardware that is recognized in NI MAX, however I can't see the device or any of its ports/lines in the DAQmx Physical Channel control in LabVIEW. I also cannot find it by clicking Browse.
Note: Make sure that you have your device connected before you begin writing your LabVIEW code and your device is added within the project. If you have already written your code before connecting your device, you will have to delete and re-drop the DAQmx channel selection control or constant. Also make sure the DAQmx and LabVIEW versions are compatible with each other.
You need to change the default I/O Name Filtering option:
  1. Right click the DAQmx Physical Channel control, choose I/O Name Filtering option.
  2. In the Filter Names panel, choose the I/O Type drop down menu.
  3. Choose any option in Port/Line Filtering drop down menu.
  4. Click OK and close the Filter Names panel.
Then you will see the listed ports and lines of your device in DAQmx Physical Channel control when you pull down the drop down menu.
The LabVIEW DAQmx Physical Channel control can only be connected to Analog Input by default, so if you are going to connect it to a digital I/O device, the ports and lines will not show up.
