Archived:Can't Build Tutorial Using Eclipse 2017 for NI Linux RT
Updated Jun 1, 2023
  • cRIO-9035
  • myRIO-1900
  • cRIO-9068
Programming Language
  • C++
  • C
Other
Windows 7
Windows 10
C/C++ Development Tools for NI Linux Real-Time, Eclipse Edition 2017
For New Projects, a Modernized Toolchain Is Advised Instead
This article explains how to use Eclipse C/C++ Development Tools for NI Linux Real-Time to achieve cross-compiling tasks. This toolset is not actively maintained anymore. It was last updated in 2018 and is currently not advised to be used for new projects.
Instead, NI created extensive documentation for a modernized toolchain, which is easier to learn and utilize. That documentation also provides information on typical steps, like building, deploying, and debugging a shared library. If you are planning to do C/C++ development and are searching for the right toolchain, then visit Getting Started with C/C++ Development for NI Linux Real-Time.
Overview of the Following Eclipse-Based Content
I'm trying to follow the instructions from the Getting Started with C/C++ Development Tools for NI Linux Real-Time, Eclipse Edition  tutorial, but I get errors that prevent from successful build. I use steps with Intel x64-based targets and 2017 software stack notes.
Are there any additional includes need to be added?
In the Getting Started with C/C++ Development Tools for NI Linux Real-Time, Eclipse Edition  tutorial, in step 10 for Intel x64-based targets, 2017 software stack you need to add the following includes to resolve the problem:​
  • C:\build\17.0\x64\sysroots\core2-64-nilrt-linux\usr\include\c++\4.9.2
  • C:\build\17.0\x64\sysroots\core2-64-nilrt-linux\usr\include\c++\4.9.2\x86_64-nilrt-linux
If you need to build a project from the tutorial for ARM-based targets using Eclipse 2017 software stack, you should add the following includes to resolve the problem:​
  • C:\build\17.0\arm\sysroots\cortexa9-vfpv3-nilrt-linux-gnueabi\usr\include\c++\4.9.2\
  • C:\build\17.0\arm\sysroots\cortexa9-vfpv3-nilrt-linux-gnueabi\usr\include\c++\4.9.2\arm-nilrt-linux-gnueabi
