How Do I Re-Enable the USB Host Ports of a cRIO Controller?
Updated Jul 4, 2018
  • cRIO-9030
  • CompactRIO Controller
  • NI CompactRIO
  • NI Linux Real-Time
I connected a monitor and a mouse to a cRIO-903x controller using the USB Host Ports. I accidentally disabled the USB Host Ports of a cRIO controller in the Configuration Options that appeared on the bottom side of the screen. Now, I cannot move the mouse pointer and select to re-enable the USB Host Ports.
You can format the disk of the cRIO Controller to re-enable the USB Host Ports.
You will lose all programs and configuration data on your controller when you format the disk. Make sure you have a backup copy of any files you may need from your controller, and make a note of your IP configuration.  There is no need to back up any of the driver or run-time files as they will be reinstalled after the format.
