Error -2147138473 When Setting Active Mode Programmatically for Third-Party EtherCAT Device
Updated Jun 19, 2026
  • cRIO-9038
  • PXI-8115
  • cRIO-9045
  • LabVIEW 2017 Full
  • LabVIEW 2017 SP1
  • LabVIEW 2023 Q3
Other
EtherCAT®
When I use the Set Scan Engine Mode VI in order to programmatically set the Operating Mode of a third-party EtherCAT device in Active Mode, I get the following error:
Error -2147138473 occurred at an unidentified location
Possible reason(s):
NI-Industrial Communications for EtherCAT:  (Hex 0x80054457) An internal error has occurred in the NI-Industrial Communications for EtherCAT software. If the problem persists, contact National Instruments technical support.
This error is shown in the following dialog box.
If the  EtherCAT SubDevice Information (ESI) File of the Third-Party EtherCAT Device includes an EEPROM section, this section of the code does not allow the EtherCAT slave to switch to Active Mode.
In order to properly set the Scan Engine in Active Mode, edit the ESI File commenting the EEPROM element. To comment an element on a XML File, you have to place the element inside the following syntax <!-- Commented Element -->.
