Does the PXIe-6570 Support Industry Standard Vector Formats (WGL, STIL)?
Updated May 14, 2025
  • PXIe-6570
  • NI-Digital Pattern Driver and Digital Pattern Editor
Does the NI PXIe-6570 device support industry standard vector formats such as WGL and STIL?
While the PXIe-6570 only supports NI digital pattern files (.digipat), there are several tools available that convert industry-standard pattern files (such as WGL, STIL) into the .digipat format that the device can use. Two of the supported conversion tools are the Test Spectrum VectorPort and the TSSI TD-Scan Pro.
