NI-XNET Error -1074384887 Synchronizing DAQ and XNET Tasks
Updated Sep 9, 2022
  • cDAQ-9189
  • NI-9860
  • IC-3172
  • NI-9205
  • NI-DAQmx 17.0
  • NI-XNET 17.5
I'm currently trying to synchronize analog input data and XNET data in LabVIEW. On the first run, the tasks acquire data as expected, however when stopping the program, I receive: Error -1074384887 occurred at XNET Stop.vi
NI-XNET: (Hex 0xBFF63009) The board's firmware did not answer a command. Solution: Stop your application and execute a self test. Try deactivating/reactivating the driver in the Device Manager. If this problem persists, contact National Instruments.
I then am sometimes unable to communicate with the devices unless I power cycle them. Is there anything I can do to prevent this error?
When synchronizing a XNET and DAQ task, ensure that the XNET task is stopped before stopping the DAQmx task. This can be enforced through dataflow techniques in LabVIEW.
