Can I Generate a List of Functions and subVIs Used by a VI?
Updated May 29, 2018
I have a LabVIEW project that calls many other VIs and functions. Is there a way that I can get the list of all of the VIs and functions that my project uses?
You can use VI Hierarchy in order to view the list of VIs that are used in your project. This can be accessed by opening your LabVIEW project, and clicking View >> VI Hierarchy. This will only give you the list of VIs that are used in your project (that have a .vi file extension). Programming functions (such as boolean logic functions, array functions, etc) will not show up in VI Hierarchy.
