Deploying DLL Driver Files on Real Time Target
Updated Jul 26, 2018
  • LabVIEW Real-Time Module
  • PharLap
I have a LabVIEW RT application, which I can build and deploy via MAX. This deploys to /ni-rt/startup.
In the deployment, there are some *.dll files, which I need to deploy to /ni-rt/system.
How can I deploy specific files to that folder?
When you build you application using build specification, can you go to destination and add a new destination by clicking on the add button, then specify your preferred path to c:\ni-rt\system
If you go to source file settings, you should be able to see the project files on the left hand side, click on the dll files, and then change the destination from the drop down menu on the right hand side to the new destination you created. Repeat for XML and startup application but this time the destination would be the original one.
