I Cannot Revert Time with NI-Sync in PPS Mode Using PCI-1588
Updated Jun 4, 2018
  • PCI-1588
  • NI-Sync
I'm using the NI-Sync API to set the time on a PCI-1588 module in PPS mode. I change the Initial Time to future times, but once these future times are set, I cannot revert back to times between the current time and the future time that I set. If I try to reset the PCI-1588 in MAX, it delivers some random data. The only way is to reboot the entire system.
This is a known issue and it will be fixed in a later version of the NI-Sync driver. For older versions of NI-Sync there is a workaround that can be used.
  1. Set the PCI-1588's time reference to Free Running.
  2. Execute niSyncResetFrequency.vi
  3. Set the PCI-1588's time reference to PPS with the desired time.
If you reset the board from NI MAX prior to following the steps above you will need to reboot the system.
