Limitations When Using The PFI Lines On My DAQ Card Or Device
Updated Jun 5, 2018
  • USB-6212
Other
USB-6212
I would like to know what limits the maximum frequency I can have for a signal I would like to use as input to my DAQ card or device.
The PFI inputs have physical limitations, which affect the maximum frequency that can be used as input for a DAQ card. If you would like to know which is the maximum frequency your card can have as input, refer to the card's datasheet. It should have a specification called "External base clock frequency" or "Max external source frequency", this specification corresponds to the limit for the PFI to take accurate measurements of the signal.
