Missing subVI DAQmx in VI NI VeriStand Engine.lvlib
Updated May 21, 2018
  • VeriStand
I am trying to run a VeriStand project but when I do I receive a "Missing subVI DAQmx..." error. How can I solve this?
This error is typically caused because the DAQmx driver is missing. Install the DAQmx driver and then you should no longer see this error.
Make sure to check the compatibility between the version of LabVIEW/VeriStand that is installed and the version of DAQmx and the compatibility between the operating system and DAQmx.
