Warning Signal Instead the Master EtherCAT
Updated May 25, 2018
  • CompactRIO Chassis
I opened a LabVIEW project that involved a cRIO used as Ethercat Master but instead the Master EtherCAT I have a Warning Signal as showed in picture below. Why?
You are in this situation cause you don't have NI-Industrial Communcation for EtherCAT installed.
If you already have NI-Industrial Communcation for EtherCAT installed check on the driver readme if the installed version is compatible with your LabVIEW version.
