Is the Drain Wire in the SHC68-68-EPM Signal Cable Connected to AI GND?
Updated May 23, 2018
  • SHC68-68-EP
In the SHC68-68-EPM cable, is the drain wire of each analog input pair connected to AI GND?
Yes, the drain wire of each twisted analog input pairĀ is connected to AI GND.
The drain wire is in direct contact with the metallic shield throughout the cable. This ensures effective grounding and protects from any electrical surges, which would find a pathway through the drain wire into the ground.
