What Is the Spring Terminal Block Compatible with NI-9264?
Updated May 25, 2018
  • NI-9264
  • 36-Position Front Mount Spring Terminal Connector
I am using the C Series module NI-9264 (spring version), I would like to check what is the spring terminal block compatible?
The complete list of accessories compatible with NI-9264 (spring version) is available in the document Series with Spring Terminal Front Connection: I/O Cable & Accessory Guide.
First, check part number (P/N) and revision of your C Series Module. The assembly part number and revision of the C Series Module is printed on a label adhered directly to the back of the module. The part number should be formatted as a 10-character alphanumeric string ######<REV>-#<VER>L.
For NI-9264 the spring terminal block compatible is P/N 196740-011 or P/N 785502-012
1for C Series Module version 1, 2, or 3
2for C Series Module version 6.
