Can I Use My Old DAQ Device with New LabVIEW Versions?
Updated May 28, 2018
  • DAQCard-1200
  • Traditional NI-DAQ
I have an old DAQ device and I would like to understand if I can use it with the LabVIEW version that I have  installed on my PC.
In order to understand if you will be able to use your old DAQ device with your LabVIEW version you should check for Traditional NI-DAQ (Legacy) and LabVIEW compatibility
Furthermore it is also necessary to check the selected drivers read-me page in order to understand if the device you want to use is supported by that version of NI-DAQ.
