- I have a Real-Time (RT) Controller in a PXI chassis that contains DAQ cards. When I open up NI MAX and click on any of my NI-DAQmx Global Virtual Channels, I receive Error -88716. I started receiving this error after I installed patches.
- I have a CompactRIO (cRIO) controller that contains DAQ cards. When I open NI-MAX and click on the test panels, I receive Error -88716
- I have a Real-Time PXI system, and I see a red X on my DAQ cards.
- I see a red X on my cRIO chassis:
Error -88716 occurred at Device Communication
Possible Reason(s):
The requested operation failed because the versions of a driver installed on the local and the remote system are different. Update the driver so the versions on the two systems are the same.
How can I fix this error?
