I am using thermocouples for my temperature measurements using DAQmx. When I am setting the range of my measurements I receive the following error:
Error -201171 occurred at Property Node DAQmx Timing (arg 1) in Thermocouple - Continuous Input .vi
Possible reason(s):
Minimum temperature specified for the thermocouple measurement falls outside of the accuracy limit when using polynomial scaling.
Specify a value greater than the minumum temperature for polynomial scaling with this thermocouple type, or set the Thermocouple Scale Type property to Table
As viewed in the following image:
