Network Shared Variable Value Not Updating Until VI Runs 2 Times
Updated May 28, 2018
Other
LabVIEW
I have a network shared variable on my project and it does not update it's value until I run the VI for a second time. I write to the variable and then read it, but the value changes until I run the VI 2 times.
Check if you have buffering enabled for this variable, it may be causing the value to be stored and released until the second time the VI runs, which updates the value of the indicator to the saved value, and stores the new selected value.
More information on network shared variables buffering and usage can be found here: Using the LabVIEW Shared Variable
