I am attempting to set up my CompactRIO, sbRIO, or PXI controller as a Real-Time target. I can see my device in the NI Measurement & Automation Explorer (MAX) under Remote Devices. When I attempt to Add/Remove Software, I receive the following error:
Error: the hard drive on the remote system is either full or encountered an I/O error.The following image shows the error message:
Also, when trying to change the IP of the Real-Time target the device doesn't keep the changes after selecting
Save in NI-MAX
