Multiple Two-Edge Separation Measurements on one CompactDAQ device
Updated Jul 12, 2018
  • CompactDAQ Chassis
  • NI-9361
  • CompactRIO Chassis
  • LabVIEW FPGA Module
I would like to make multiple period separated measurements for several Units Under Test using the Two-Edge Separation Measurement Task. How can I implement this one one cDAQ?
A cDAQ can support the same number of Two-Edge Separation Measurement Tasks as the number of counters on your cDAQ. The NI-9361 Counter Input Module only supports Two-Edge Separation Measurements on a cRIO FPGA, and cannot be used on a cDAQ for that type of measurement. It does support many other counter measurements. Please see the NI-9361 Datasheet for more detail.
