The Difference Between Internal Calibration and Self Calibration
Updated Jul 12, 2018
I'm calculating the Absolute Accuracy of my device. I've noticed datasheets for DAQ devices sometimes refer to an "Internal cal" and other documents refer to a "self cal." NI-MAX only has a self calibration. Is there a distinction between an "internal cal" and a "self cal"?
These two terms can be used interchangeably.
Self Calibration is used to calibrate a device for temperature changes based on an internal reference voltage. The reference voltage is routed to all channels on the board, then read at a variety of gain settings and compared to an expected value. For more detail see: What Are the Differences between Self-Calibration and External Calibration?
