This error indicates that there is insufficient location information of the device or the resource is not present in the system.
Please try the following steps :
- Check the connection of the device and verify that it is correctly connected.
- Verify that the NI-VISA Runtime is installed on your computer. If not, install it or consider creating an installer for your application.
- Copy the DLL/LLB of the device driver into the same folder as your project.
