CVS I/O Accessory 44-Pin Compatibility with IC-317x Series
Updated Apr 23, 2023
  • Industrial Controller
  • CVS ACCESSORIES - I/O Cable
  • CVS ACCESSORIES - Adapter/Connector
I have a CVS I/O Accessory connector block wich gives me direct acces to the 44 DSUB pins on the NI Compact Vision System. Is this connector board also compatible with the IC-317x series Industrial Controllers?
Yes, the pinout of the CVS devices and the 317X series Industrial Computers are identical, thus you can use the CVS I/O Accessory connector block to acces the 44pin DSUB connector of the Industrial Controllers. The Pinout of the CVS I/O Accessory will also represent the correct pins.
  • CVS I/O Accessory and 3 meter 44-pin D-SUB male to 44-position D-SUB female cable (part number 783327-01)
  • CVS I/O Accessory and 0.5 meter 44-pin D-SUB male to 44-position D-SUB female cable (part number 783328-01)
