This usually happens if you have a PXI/PXIe controller with a Real-Time OS.
- If you were trying to boot Windows, verify that you purchased a controller with Windows installed or that you have installed it manually.
- Make sure that the correct switches are flipped on your controller. Try turning on only Switch 1.
- If the error continues, try booting the controller in RT Safe Mode by turning on Switch 2.
The user manual of your controller will have information on the functionality and location of the switches on your controller. See additional notes for an example of this information.
If you send your controller to be repaired by RMA, they will revert the operating system and BIOS settings back to the original configurations they were purchased in. If you choose to put a different operating system on your controller, you must make sure the boot configuration is set up correctly as explained above for your operating system.
