Bad Conversion DBL in Boolean Array with Number to Boolean Array Function
Updated May 16, 2018
  • LabVIEW NXG
I used the Number to Boolean Array Function to convert a DBL into boolean array in LabVIEW NXG. The Array result is not the expected value. How can I fix that ?
The expected number at the input of the Number to Boolean Array Function is a U32. So you can see a coertion dot who convert automatically the DBL in U32 before to execute the function.
To convert DBL in Boolean array, you have to use the Flatten to Byte Array Function :
Basically, avoid automatic numeric conversions. To improve code performance you have to remove all implicit type conversions (coercion dots). Use the Conversion functions to explicitly convert data types because it avoids a copy operation and a data type determination.
