Configuring the Flyback Diodes of a PXI-2567 For an External Power Supply
Updated Mar 26, 2025
  • PXI-2567
I am planning to use a PXI-2567 to drive relays, but I want to use an external power supply instead of the internal sources from the card. How do I configure the relay driver card's flybacks to route to the correct power source?
The flyback diodes on a PXI-2567 neither can nor need to be configured. They are internal to the card and are set in parallel with each channel’s circuitry to protect the card’s channels, regardless of whether the power source is internal or external to the card. The PXI-2567 Channel Diagram section in the PXI-2567 User Manual shows a flyback Zener diode in each channel.
When you are driving an inductive load through a switch, a phenomenon known as flyback will cause a sudden voltage spike, which can be much larger than the supplied voltage, when the switch is opened power is interrupted. This voltage can damage the circuity on a switch, so the flyback diodes were included on the PXI-2567 to prevent this damage.
