Error -1967362032 When Remotely Reading Shared Variable Properties
Updated Oct 13, 2024
  • LabVIEW Base
  • LabVIEW Professional
I deployed a Shared Variable on a target machine. I would like to programmatically view the Properties of this Variable across the network.
When shared variables are hosted on the host PC I don´t have any problem viewing the properties using Property Nodes in my block diagram, but when I try to view properties from a shared variable hosted in a remote PC, the property nodes display the following error with some properties:
Is this expected behavior? How can I work around this behavior?
This is expected behavior. The only properties supported by Property Nodes in a remote PC are:
-Set mode
-Name
-FullURL
-DataSocket URL
-Process
The rest Shared Variable properties are only accessible from the PC hosting the Shared Variable.
It is possible to view and read Properties using a Data Socket Read or DataSocket Write VI, respectively. The format of the Alarm Level address is the following:
//<machine name or IP>/<library name>/<variable name>/Alarms/HiHi/level
For more information about DataSocket for LabVIEW refer to related links.
