Cannot Add Device to myRIO Project
Updated Jun 8, 2018
  • sbRIO-9607
  • myRIO Student Embedded Device
I'm trying to add my target device to a myRIO project template I've made in LabVIEW but I get an error that says "Target you specified is not a myRIO device".
This can occur if the wrong type of Project Template is used when starting a RIO based project.
Check to see if your device is a myRIO product.  It will match the Part Numbers of the devices below: If the device does not match one of the models above, you will not be able to add it to the myRIO Project Template.
Instead, try adding the target to a blank project.
