Error 2711 NIFeature with LabWindows™ /CVI™ or LabVIEW Installer
Updated Jun 15, 2018
  • LabWindows/CVI
  • LabWindows/CVI Application Builder Module
I built an installer from LabWindows/CVI 2017. When I run the installer on another computer, I get Internal Error 2711. NIFeature.1.2C11DE87B6C10.MDF100.
How can I resolve this error?
The error may occur due to one of the following:
  • Incompatibilities between EXE bitness and Operating System bitness. Confirm that you are not trying to install a 64-bit EXE or driver onto a 32-bit system.
  • Corrupt National Instruments software. You can Force Reinstall your software (either LabWindows/CVI or LabVIEW)
If you are still running into issues, consider generating an installation Error Log and contacting NI Support.
