Does NI 9223 Support Single Cycle Timed Loop Operations?
Updated May 18, 2018
  • NI-9223
  • LabVIEW FPGA Module
I want to use NI 9223 Read I/O Function inside Single Cycle Timed Loop (SCTL). When I Right-click the function and select Execution Mode»Outside single-cycle Timed Loop or Inside single-cycle Timed Loop to specify where the function executes, It doesn't show up. Why?
According to the help file
​NI 9223 (FPGA Interface)
NI 9223 does not support the single-cycle Timed Loop operations
