PXIe- 4303 Error -200077 Occurred at Property Node For Start Delay
Updated Jun 28, 2018
  • PXIe-4303
I am trying to set a timed trigger delay to the PXIe-4303. I get an error if the time delay if not set to 0 seconds. Why?
The PXIe-4303 does not support setting the time delay to a value other than zero.
Another method will need to be used to create the delay on the PXIe-4303 such as:
  • Tossing out a number of initial samples
  • Using a counter device or external circuitry to create a delay, if the delay needs to occur between an imported start trigger and the start of the sample clock/acquisition
