How Can I Disable A Counter PFI Line in LabWindows™/CVI™?
Updated Jun 15, 2018
  • PXIe-6358
  • LabWindows/CVI
I have a counter that is routed internally and I would like to disable the PFI line output so I can use the PFI for another use. How can I do this?
If you are trying to use a counter's default PFI line for another use, the best practice is to directly route your signal or connect your terminals to the PFI line and it will overwrite the counter output.
