Unable to Import NI-DAQmx Task from MAX into SignalExpress
Updated May 28, 2018
  • SignalExpress
LabVIEW Signal Express has a menu item "Import NI-DAQmx Task from MAX..." in the Tools menu as seen in the image below.
When I use this to import a previously configured NI-DAQmx task from Measurement & Automation Explorer (MAX), a empty DAQmx step is placed down in the project and I am prompted to select my channels, even though I have already done so when the task was created.
This is actually a reported bug in NI-DAQmx version 9.1.5.
However, this has been repaired in NI-DAQmx version 9.2.2. Upgrading to 9.2.2 or later will resolve this issue and allow you to properly import your data acquisition tasks from MAX.
