How Do I Add a Finite Number of Elements in an Array?
Updated Jul 23, 2024
How can I update an array with new data as the VI is running?
In order to add values to the array, you need to keep track of the elements already in the array. To maintain previous data, you need to use shift registers.
Below is an image showing an example of implementing shift registers to maintain the values previously added to the array.
