Error -1074118627 Occurred at NI Initiate VI
Updated Mar 12, 2019
  • USRP Software Defined Radio Device
  • USRP Software Defined Radio Reconfigurable Device
  • LabVIEW Communications System Design Software
  • NI-USRP
I am using a NI-USRP device from LabVIEW or LabVIEW Communications and  getting the following error:
Error -1074118627 occurred at niUSRP Initiate.vi
Possible reason(s): A runtime or configuration error occurred. Code: 2410 Details: LookupError: Path not found in tree: /mboards/0/dboards/A/rx_frontends/0/sensors/lo_locked
This issue has been known to occur on older USRP images. Upgrading to the latest version of NI-USRP and updating the firmware and FPGA Image from NI-USRP Configuration Utility should fix the issue.
Please go ahead and reach out to ni.com/support if the issue still occurs after that point.
You can download the latest version of NI-USRP driver from here.
