Does NI Support HDF5-1.10.2 DLL?
Updated Jun 5, 2018
I would like to know if I can use the HDF5 1.10.2 dll release with LabVIEW 2017, and how would I be able to do so.
The add-on recommended for using the HDF5 data model, library and data file is HDF5 Live, you can see this information in the article: Use HDF5 files in LabVIEW
There are other tools, as the article says, one of them is h5labview, which can be found here: HDF5 bindings for LabVIEW - h5labview
However, as you may see on that webpage,the v1.10.X branch of HDF5 is not yet supported.
Here is the link to the recommended tool: Live HDF5 by UPVI
Note that support for this tool is provided by UPVI, on the resources listed on the product's page.
