Archived:After Deploying an Image to My cRIO, the Scan Engine Interface Is Not Working
Updated May 3, 2021
National Instruments does not actively maintain this document.
  • cRIO-9031
  • cRIO-9068
I am using a cRIO controller and after deploying an image to it using the RAD utility, the scan engine interface appears to be not working. Error code -66208 is coming up mentioning that the scan engine needs to be initialized and that the modules are not being referenced properly.
This indicates that the current chassis/controller is not able to recognize the settings, modules, or other variables when the image was deployed. Some suggestions you could do to prevent this error:
1. Ensure all IP addresses/settings are set correctly for any cRIO controller/chasssis.
2. Ensure that the code matches what is placed in the cRIO chassis/controller. For example, if the code is asking for a specific module to be in slot two, check to see if that module is in slot two of the chassis/controller receiving the deployed image.
