此內容不適用於您所偏好的語言。
此內容已顯示為其他適用語言。 您的瀏覽器可能含有可協助翻譯的套件。
Unable To Connect To Camera Error 0xBFF6902C
Updated Apr 14, 2023
  • NI-IMAQdx
I can see my camera in Measurement and Automation Explorer, but when I attempt to connect to it the following error is shown
This error might be occurred because of two reasons.
  • IP settings of the camera
This error occurs when both the primary NIC on the controller and the accessory Gigabit Ethernet/Ethernet card possess IP addresses within the same subnet. To resolve this issue, modify the IP address of the Gigabit Ethernet/Ethernet card to an available address on a different subnet. Then, ensure that the camera IP address is also changed to the new subnet. This will allow you to successfully access the camera.
For example, if the camera is configured with a network address of 192.168.x.x, then the NIC must be configured with a similar network address of 192.168.y.y.  To reset the address on the interface, do the following:
  1. Open Network Connections.
  2. Right-click your Local Area Connection and select Properties.
  3. Select the General tab in the Properties window, and select “Internet Protocol (TCP/IP)”.
  4. Click the Properties button, and verify that “Obtain IP Address Automatically” is selected.
  5. Select the Alternate Configuration tab, and verify that “Automatic private IP address” is selected.
  6. Return to MAX. The camera should now appear in the configuration window
  • Wrong connection port
The second reason that could cause this error is wrong port connection. Refer to the device manual for providing correct connection.
