NI Package Manager There Was a Problem Retrieving Available Products on the Browse Products Tab
Updated Dec 18, 2023
  • Package Manager
When I select the "Browse Products" tab in NI Package Manager I get either of the following error messages and my Internet connection is working.
There was a problem retrieving available products
Value cannot be null.
Parameter name: source
Please check your Internet connection and try again.
Request failed with status code: 'InternalServerError'.
Before trying the steps detailed below Restart your machine. If this does not resolve the issue, try the other steps below.
This issue can be the result of a proxy server that allows traffic to pass either with a login or without (also called non-authentication proxy), when your operating system has stored invalid and/or incomplete login credentials.
Follow these instructions to revise your settings:
  1. Open your Windows' Control Panel.
  2. Navigate to Credential Manager » Windows Credentials » Generic Credentials.
  3. Check if there is any credential record for your proxy server stored. It can either be under the proxy's IP address or its name.
Note: In this screenshot incomplete credentials to a local proxy are shown; the entry is missing a user name.
  1. Delete the invalid and/or incomplete record.
    • Note: Be aware that there might be another application relying on this record. That application will either create this entry again automatically or ask you to re-enter the credentials.
    • Be careful deleting credentials you don't know. You might have to contact your IT/Network Operations/admin to restore them.
  2. Restart the NI Package Manager.
Another potential cause of this error could be related to network protocols:
  • Currently the TLS 1.3 protocol isn't supported from NI Package Manager.
  • If you are using this protocol, try disabling TLS 1.3, reboot the system and then retest NI Package Manager
NI Package Manager is a software to download, install, manage, and upgrade NI software like LabVIEW & TestStand. It also gives access to additional drivers, modules, and add-ons.
NI Package Manager is a different product than the VI Package Manager. The latter provides easy management and distribution of add-ons for NI LabVIEW editions.
