LabVIEW Timestamp Data to XML Showing Unexpected Values
Updated Sep 5, 2018
Other
XML File Format
I cannot understand the time stamp values in my XML file generated with LabVIEW. I am just using the Flatten To XML String function to flatten my timestamp control and write it to a file:
But my XML data is not the total elapsed time since 1/1/1904 00:00:00.00 UTC as I expect:
Why is this happening?
The XML formatting of your timing should display the total elapsed time in seconds from 1/1/1904 00:00:00.00 UTC.
The problem we're facing is that the Flatten to XML String converts your data into a signed, 32-bit value. The absolute max number for a signed 32-bit value is 2,147,483,647. Because any date after ~1974 will have a larger number of elapsed seconds (since 1/1/1904) than 2,147,483,647, we experience some sort of rollover, which is the data that's displayed in your XML file.
Here is an equation we can use to account for our rollover:
XML Elapsed Time = -[ MAX of U32 - (Total Elapsed Seconds - MAX of U32) ],
where MAX of U32 is 2,147,483,647, and Total Elapsed seconds is the total number of elapsed seconds from 1/1/1904 00:00:00.00 UTC.
You can refer to the attached VI for an example of both rollover and this calculation.
