Change Outputs from Vision Assistant Express VI
Updated Jun 14, 2018
  • Vision Assistant
  • Vision Development Module
I am using the Vision Assistant Express VI, and I would like to change the information I pass from the output terminals in LabVIEW.
How can I modify the input and output terminals (controls and indicators) for the Vision Assistant Express VI?
  1.  Open the Vision Assistant Express VI for configuration. You can do this by right-clicking the VI and selecting Properties or by double-clicking the VI.
  2. In the bottom right corner, click the Select Controls>> button.
  3. This should open a window that displays a list of all possible controls (inputs) and indicators (outputs) that you can choose to use for the Vision Assistant Express VI.
    1. If an object is selected (checkmark in the checkbox), you will have access to this in your LabVIEW code.
  4. Select Finish. You should now be able to access any controls or indicators you selected from the Vision Assistant Express VI input and output terminals.
